Hi ksa8907,
It does have adjustable valve lash I think. I plan to get the valve lash adjusted when I replace the timing belt later this year. I'm using 5w-30 full synthetic oil.
Originally Posted by ksa8907
Because you're filling the valve covers woth oil, muffling the noise. I would suggest draining the oil and using a thicker oil if the noise is a concern. Or, does your engine have adjustable valve lash?
