Old 02-27-2017, 11:08 PM   #5 (permalink)
snakedog
Hi Frank Lee, I know its not covering the valves. I am wondering if anyone else noticed the same thing.
Wondering if the weight of the oil is not right since it is synthetic. Or maybe the synthetic doesn't coat the valves as well as it should.
Or maybe the age of the engine requires a different weight oil in order to properly lube the valves.
I will be getting the valves adjusted soon.
Adjust the lash, don't overfill, you are NOT filling the valve covers with oil.
