I can tell you from experience with Hondas engines, setting the valve lash to factory specs certainly does quiet valve train noise.
Snakedog, next time you do your oil, replace 15% of your oil capacity with Marvel Mystery oil. It may or may not work, but certainly wouldn't hurt things. It helped with my ticking noise on my Miata significantly.
