Hybrids run very high voltage battery packs.
Solar panels typically stay well under 100 volts.
A watt is still a watt. And you could run all the cells in series to whatever voltage you wanted with the appropriate wire guage within the pv's.
"20+ from a gas one ton!? INCONCEIVABLE!!!"
-Every other forum i tried to state my intents...
Total spent on mods. :$440($200 was oil. So take it or leave it)
Total returned from 10mpg baseline :$167
miles since i started ecomodding :3315 miles
