Old 03-03-2017, 09:15 AM   #80 (permalink)
Fat Charlie
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Originally Posted by Sparkeysmall View Post
A watt is not a watt when talking solar power.
Enlighten me.
Lugging your power generation equipment around is inefficient. Ignoring the aero penalties of solar panels and the silly inefficiencies of vehicle mounted panels, the weight would be better spent on battery capacity. Think of it as a couple 5 gallon gas cans in the back instead of a mini biodiesel refinery filling the bed of your truck.
Upping the compression ratio, or doing anything else to your engine is going about things backwards. Your truck is one of the sloppiest, most inefficient messes on the road. It's heavy and unaerodynamic with gobs of rolling and powertrain resistance being pushed around by a big V8 through an automatic transmission. Driving it is like moving a bean bag chair around by kicking it. You seem to think that changing the way you kick it will change the way it moves, but it's still a bean bag chair even if you get Adam Vinatieri to kick it. Work on what it does once you've fed power to it before you worry about the exact way you feed power to it.
It doesn't take much of a gain to make a huge difference in your rig's economy, and that's great, that's our focus here. Trying to do it backwards leaves that gain sitting on the table, wondering why you don't want it.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
Xist (09-11-2017)
