Craig Vetter still has replacement hardware available at the craigvetter.com. Ammo cans are available for lower storage. Cut a plastic waste can to fair the shape front and back. If positioned right they will fit so a second rider will have leg clearance and some protection. A tapered top box and back rest could be made from honeycomb aluminum. I would suggest mounting rails so that it could slide back for the second rider or be easily removed. See Chapter 7 of "Proficient Motorcycling, The Ultimate Guide to Riding Well" by David L. Hough.
