Had the AC line rub a pinhole in the hot side IC boot. It just looked like a chafed spot on the passenger side boot. It blasted a hole in the hood insulation 1.5' above and would only make 12psi. Made 15psi after repairs but I'm 1st gen with a non wastegated H1C turbo-charger. 32 sounds high unmodded
You want MORE BOOST? Read here!
Explains there are 2 modds needed to pass the 20psi mark.
Tells you what to look for and how to undo/reverse engineer.
What are your EGTs running at cruise/ psi. Vs pulling a grade. What EGT corresponds to your 15psi?
For me its 1000°f=15psi. 1050 during turbo lag aprox 1-3sec.
Depending on wether 5-600° 1-3psi in the flats between Anaconda and butte.
Any one got a HX35 laying around I'm looking for a wastegated ehxsost ?
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
