Thread: 70mpg @ -13F
Old 03-05-2017, 12:48 AM   #18 (permalink)
stovie
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
If you could insulate the engine and bypass the radiator you could probably get better economy!! It would also make it easier to heat the engine with your block heaters in the end also!! Considering the low temperature where you live I would suggest taking out the thermostat and plug the bleed hole in it with a small weld or something.
