Old 03-13-2017, 08:44 AM   #65 (permalink)
Hoopie
Hoopie
Hoopie's Avatar
Is the new hole in the firewall higher than the old one? Do you think a 4-bar linkage would be stouter than the extension?
For sake of argument, suppose I wanted a stance more like the R&C Dream Truck?
This answers the question about the cowl/cowl relationship. For the gas tank, could you rotate the whole thing 180° and run that complex filler subsystem up the inside corner of the cab.
The hole in the firewall is only a couple inches above the original location. I'm not sure what you mean by four link. Could you illustrate? I wanted to go lower but the issue was with the strut towers. With the current stance I only have a 1 1/2" gap between the strut and the fender. Concerning tank rotation, all the other fuel lines came in on that side. I didn't want to relocate them. The tank is in the exact place as it was in the Prius. One more way that it fell together.
The Following User Says Thank You to Hoopie For This Useful Post:
freebeard (03-13-2017)
