Old 03-15-2017, 08:07 PM   #8 (permalink)
kach22i
I would also fear it to actually increase the pumping losses.
Even though the heat generated would eventually be almost negligible, it's still not going to be converted back into "pressure", neither control so effectively to which direction it would be applied.
What if it were applied to the first gif below?
914World.com > Camless engines
The spring would probably make it go crazy in two directions instead of one.
Well, how about some conventional layouts?
Professional Automotive Repair | Timing Belt Replacement - Professional Automotive Repair Atlanta | Marietta | Car Maintenance
engine - what is difference between DOHC and SOHC? - Motor Vehicle Maintenance & Repair Stack Exchange
https://www.pinterest.com/pin/339810734358256743/
Camshaft VVT
Double overhead camshaft (DOHC) - 4 stroke engine with fixed valve timing that the valve train is set by the auto maker for peak efficiency running at a specific point in the engine's operating range, and
These Gif's are a lot closer for discussion purposes than the bicycle diagram/video. The bike one was a "what if" the up stroke was powered. Kind of a side bar distraction, trying to stay focused.
There are a lot of stresses on conrods/rods forces from all directions, just not feeling a spring application in my bones.
https://grassrootsmotorsports.com/fo...r/50017/page1/
https://www.tomeiusa.com/_2003web-ca...60_conrod.html
The forging process ensures that the conrod is capable of high stress loads at high RPMs when the tension loads exceed 1 ton.
I'm afraid to think what a one ton spring looks like.
DieselJan (03-16-2017)
