Thread: Warm air intake
Old 03-15-2017, 09:41 PM   #29 (permalink)
stovie
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
Would a workaround with a motorcycle stator be totally out of question? Well, since it wouldn't require a belt or a gear drive, presumably there will be fewer drag added to the driveline. If you eventually decide to go that way, making an enclosure similar to a brake drum for the stator and fit it between the transmission and the driveshaft like it was done with those older trucks with a transmission-mounted parking brake would be the way to go. Roughly maintenance-free too.
That would take quite a bit more to get it working!! All I got to do to get the alternator working is to bolt it in place and put a belt on and it's finished!! Using a stator would require some more alterations than I'm willing to do right now! But it would be better in the long run!!
