Old 03-17-2017, 05:04 PM   #3009 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
thingstodo, for the pump, you have 3 phases to work with, so you could use one of the 3 for a boost converter, and then the other 2 for generating the 120v or 240vAC. I can do up the code when you are ready to do that.
I have a large (300 A, 800V rated) inductor that I can use for the boost ... it's actually bigger than the controller and *MUCH* heavier but I have it and it should work fine.
I should start on this project ... this weekend ... since I need the sump pump to run for our upcoming spring season
But I'll be loading the 3 phase code first and going through some testing to make sure all is wired correctly before I start with the experimentation.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
