Originally Posted by kach22i
I've done these types of overlays maybe 100 times by now, just went ahead and did this one.
Some may disagree with the foil/wing option shown in pink. It's a idea which came up with an aerodynamist over coffee, but was told this cavity is best filled in to the recommended angle.
I just think it would look cool with a few diffuser/vane straighteners both vertical and horizontal. Although not the best in snow climates or on maintenance and cleaning. Might make good place for spiderwebs and bird nests too.
wow it's marvelous what this tool is capable of, I wanted to try as you suggested but couldn't work with it on mobile device. I'll try drawing some alternative designs based on this. I think the rear end could be a vertical line instead of a pointy apex, sort of like the wing as recommended. and the front end could be a more aerodynamic bubbly oval area instead of the the plane-like nose which albeit looks cooler imo.
