Old 08-15-2008, 05:08 PM   #29 (permalink)
Rolf
Originally Posted by elhigh View Post
{snip}
Another idea is to have the conrod rigidly attached to the cylinder and project through a solid bottom in the cylinder, and the top be IC and the bottom is steam. That may be difficult to lube though - how did they do it with the old steam engines?
I think this idea is even more practical than the original 6 cycle setup. The bottom steam engine cylinder could be engineered as a regular steam engine with the exception that it would generate its own steam when water was injected. The two cylinders would be constructed so that the heat from IC engine could be used by steam cylinder.
A temperature monitor would determine when the water would be utilized, the rest of the time it would just idle.
My first post, nice forum!
Rolf
