freebeard
The encoder/resolver is on the back end of the altermotor. There is no room for a fan.
Rig up a belt drive fan off the front shaft/pulley. Might need a jackshaft to do it.
Oh. VW. Forgot how they work. Fan on generator. Let me check around how others do it.
edit--Ummm, why do you need air cooling if you change out the engine for an altermotor ?? Cabin heating, maybe ?
