I had this idea on how to decrease the aero-penalty of cooling your engine:
(coolant flows right to left in the picture)
By making the radiator behave more like an opposing flow heat-exchanger it should be possible to reduce the amount of air that needs to flow across it. Since most radiators are over-sized for ecomodder needs, the decrease of max cooling power should be no problem.
