Old 03-23-2017, 03:11 PM   #3 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 37.93 mpg (US)
Twice the air flow per square foot of radiator frontal area, plus all the turns, will restrict air flow and cause cooling problems on hot days.
Better to put in an oversize radiator. The larger radiator will give better air temperature rise, which will give the same total cooling using less air. Less air through the radiator is less air drag. Such a system may need diverging vanes to spread the air from the small grille opening evenly over the entire radiator.
The Following User Says Thank You to JRMichler For This Useful Post:
Xist (03-30-2017)
