Old 08-15-2008, 08:53 PM   #25 (permalink)
equation112
equation112's Avatar
Diva - '07 Scion tc semi-custom
90 day: 27.11 mpg (US)
I understand that oversteer/understeer characteristics for passenger cars are directly related to manufacture's recommended tire inflation pressures.
tire pressure is only part of the equation, and not so much as your sources would have you believe. suspension setup is easily as important at all speeds - I believe it is even more so, so long as the tires are in good condition and inflated to within a certain range of psi of each other. for instance, my tc from the factory is recommended to have tires at about 34f/32r. when I increased the pressure recently (my current tires are rated for 51psi), I set it for 48f/45r, in order to maintain the pressure ratio from front to rear within an acceptable relative range.
Low speed understeer is considered an attribute by carmakers for the 99th-percentile motorist.If your driving in oversteer conditions,your driving beyond the weather or posted speed.
oversteer can be induced in a number of ways at any speed, but I fail to see how understeer could ever be considered a desirable attribute under any circumstance or at any speed. remember, when a car understeers it is effectively losing all steering control (like I stated previously), as opposed to an oversteer. personally, I am utterly terrified when the front end breaks loose, because at that point the car is going to go wherever the hell it wants, and I have effectively no say in the matter.
remember class... understeer=bad
I take offense to the saying 'it isnt rocket science' to describe the relative difficulty of a given endeavour. Rocket Science is NOT hard... just EXPENSIVE
