Old 03-24-2017, 01:45 PM   #7 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.42 mpg (US)
Counterflow heat exchangers are most effective when both fluids have large temperature changes as they pass through the heat exchanger. Automotive cooling systems have relatively small temperature change on the water side, therefore counterflow has small benefit.
If you have the space to make air flow as shown, then you have the room to make the radiator thicker. The air will then go through as in existing radiators, but come out closer to the water temperature. If, that is, the air flow is reduced to the minimum with a properly designed grille block.
There is an excellent book that covers this subject: Compact Head Exchangers, by Kays and London.
The Following User Says Thank You to JRMichler For This Useful Post:
Xist (03-30-2017)
