Originally Posted by Roman
What's the differents between a dry and wet test?
Dry is just test it, add nothing.
Wet is add a little oil then test. Add oil directly in spark plug hole to piston. Just enough to "wet" the cylinder rings. This "seals" rings and shows if bad or not.
