Old 03-25-2017, 07:10 PM   #82 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Latest reports:
1: Replaced CDR (PCV) Valve as it was leaking oil. Oil usage reduced, I'm not sure if it helps with anything else.
2: Plan to install new Oil Cooler Lines purchased from Lubrication Specialist (linked below,) the stock ones are prone to leaking and blowing due to their design. I read gas versions are like that too but don't know if they are.
97 and Later 6.5TD Oil Cooler Lines: Espar Heater Parts, Diesel Truck Heaters - Lubrication Specialist
3: Still have the Oil Bypass Filter Kit which I also plan to install after installing the lines.
4: Made cardboard template for rear wheel skirting.
5: Planning to make skirting under the side steps after working on the lines and bypass system.
6: Planning to make modifications to the front air dam for better airflow and structural support.
7: Purchased Fuel Additives:
Opti-Lube Boost!: Claims to increase Diesel Fuel's Cetane (ignitability) rating by 7-9 (or 11 if you read the sales brochure) points which quiets the engine, decreases emissions, increases performance and MPG.
Opti-Lube XL: Fuel Lubricity Improver. My engine was built before ULSD Fuel came about and this is supposed to reduce wear on fuel system components.
I haven't tried the fuel additives yet. After overtreating the first time I'll use Boost at the max treat rate and XL near the max treat rate.
Another note: Opti-Lube makes another fuel additive, "XPD" (favorably mentioned in the thread linked below) but it's more of an an all-around additive that doesn't increase cetane or lubricity as much.
http://ecomodder.com/forum/showthrea...ive-26910.html
