Old 03-28-2017, 11:37 PM   #39 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by teoman View Post
Heated alcohol will need to be in a pressure vessel. Very mild pressure, but still pressure, or you will realize that your alcohol has escaped. (Or any alcohol that is after the checkvalve, before the nozzle).
Why?
The water tank will not be heated, so the water-ethanol mixture will be at ambient. If anything, I will probably need to vent the tank to the outside.
The pump will pressurize the water/ethanol mixture to well above 134 kPA, which is the vapor pressure of 50% water/ethanol mixture at 90 C. I'm probably going to shoot for about 600 kPa, which should be at the upper limit of operation for a fuel injector.
The pressurized mixture then fill an accumulator which will even out the pulsations generated by both the pump and the E85 injector, then will travel approximately 3 meters from the rear of the Magnum to the engine compartment. There, the mixture will finally be heated to 90 C in the heat exchanger, then will travel a short distance to the E85 injector itself.
I can't seem to find a reliable check valve that completely prevents backflow, so I'm probably going to use two of these water injection solenoids I have lying around. One solenoid will be placed right after the pump, and the other solenoid will be placed right after the accumulator. All of this water injection equipment I have is from an aborted project to turbocharge the engine in my old Sebring Convertible, before it lost one of its conrod bearings and grenaded itself.
