Old 03-31-2017, 01:57 AM   #366 (permalink)
oil pan 4
If bulk charging will cause the generator to run at or above half its name plate capacity an inverter generator will save you no fuel.
This is why I only buy direct drive generators, if I need a little power then I use a pure sine inverter connected to a battery.
