Old 04-01-2017, 01:44 AM   #10 (permalink)
bondvagabond
vandle - '93 Ford E-350 Xlt
The other day I pulled 6 of 8 exhaust studs on a turbo at the wrecking yard. I was able to swoop in and finish pulling the 6.5 turbo before someone else could steal my hard work.
What do you guys think are the cheapest boost Gauge/pyrometer that aren't garbage? I want to get those on board before adding the turbo.
My th350 didn't kick in when cold till the revs came up a bit, from the research I've been doing that means it needs a reseal at least. Aparently it is from low fluid pressure in the trans from internal leaks. That would fit with the history of the truck. It sat for at least 6 years before I got it running again.
Don't really want to put money into the th350, so will keep my eyes pealed for a good trans deal.
2007 Silverado 3500 classic duramax diesel, Allison 6 speed auto, extracab long bed. Doing head gaskets, will probably do econo tune and aero mods next.
Mad max would have driven a metro
