Old 04-02-2017, 03:17 PM   #67 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by HaroldinCR View Post
I'm thinking the Honda Civic is a lower voltage system. If there was a way to add the buck/boost daughter board to Paul's board, and then use the Honda power parts, or some higher powered stuff from another controller I have, I might be able to work out the controller, with lots of help from time to time.
I would be game to try the SMD soldering, simply because I can't afford to buy a completed board from Paul. I'm already into this mess for $4000.00, on CC, until I sell some stuff to make big payments.
Here are the pictures I took of Paul's populated controller board, with a T square so you can see the size.
EDIT: 10.5 inches long, 4 inches wide, just over 1 inch thick
ID:	21425   Click image for larger version
ID:	21426   Click image for larger version
ID:	21427   Click image for larger version
ID:	21428   Click image for larger version
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following 2 Users Say Thank You to thingstodo For This Useful Post:
freebeard (04-02-2017), HaroldinCR (04-07-2017)
