Originally Posted by MetroMPG
Now if only they would interview an engineer to explain why stop/start systems don't cause additional engine wear from oil drain-down.
How long do you let your car sit before draining the oil? Seriously, if a minute or two of sitting with the engine off causes wear issues from oil drain back then the engine must be nearly at the point of self destruction or very badly neglected.
The article you quotes states that the off time is generally 45-90 seconds.
