Metrompg, i am not far from you. I live in brighton. about 2hrs west of you. As for gear ratios, factory availability is 3.08, 3.42, 3.73, and 4.10. Ive considered going to a 3.73 for a lower cruising rpm, but not sure if my little 4cyl will have enough to get it moving at first.
I could easily change to a warm air intake by removing the baffle that blocks it from the engine.
As for the bed, what i should add is that i would do a step shaver/roll pan setup in the rear. Which would essentially be "boat tailing" the rear, but i do understand what you're saying about the void between the cab and front of the rear fender
