What we really need is someone driving a Prius. They get rewards for 4 cyl Hybrid and for the Generation of Prius. Each year, either a local or the Toyota Dealership guys take it when we have 3+ Insights competing against each other. It seems though that the new years Prius model always raises the bar over the old ones.
Anyone who drives an electric car (or plugin) has pretty much a cakewalk now for the most fuel efficient car. If its rated from 90-118mpge, driving it right will give you at least a 30% if not 50% boost.
The GGP is not just about eco cars though. A good driver with the right technique can easily take the 4cyl, 6cyl or 8cyl stock gas or Diesel. And if you're car is stock, all the better because you compete against a much larger field.
Also, i tried looking for you Grant53!
I try to be helpful. I'm not an expert.
