Trying to figure out what material to use for a kamm setup, I want a clean design so no coroplast, it's gonna be a "factory style" setup if that makes sense, so not huge, need to use something that can hold up and won't sag or need bracing, wanting a kind of plastic, found something called expanded plastic PVC that sounds good, thoughts?
"Ignorance is bliss, but only for the ignorant"-Hypermiler1995
