Old 04-09-2017, 08:40 AM   #1 (permalink)
Wiegraf
Driver Mod
Wiegraf's Avatar
Coqui - '99 Honda Civic DX
Turbocharging? Vacuum? Too much thinking. Smart people unite
On 2 identical motors.. one n/a , one turbocharged.
Cruising at or closer to 0 inHg
Vs
as much vacuum as possible....
which is better for MPG?
I know cruising closer to 0 inHg is counter to what is efficient.
My thinking is while cruising at
(Example incoming)
60mph at 2000 rpm in N/A car at 16inHg (or whatever a vx cruises at)
Or
60mph at 2000 rpm in Turbo Car at 0 inHg/PSI ( give or take 1 or 2 in either direction psi or inHg)
The turbo car has more loss in Mechanical Efficiency (ME) from driving turbine wheel (albeit small) and Thermal Efficiency (TE) but it is also using free wasted energy (in the form of Hot exhaust gases) to spool turbine to Force more air into a cylinder thus increasing Volumetric Efficiency (VE). Also at closer to 0 inHg/PSI there is less pumping losses associated....
This is alll just early-morning-drive-to-work thinking....anyone want to chime in.
Also to add.. this was originally posted on my Facebook and the loss and thermal efficiency was a problem because I was referring to normal car and heat soak. However in the interest of this form a lot of people use a warm air intake so I'm wondering if the thermal efficiency will actually be a benefit as far as this conversation
Current garage
- 1979 mustang street/strip
- 2010 Hyundai Accent GS 5-Speed (hate this things final drive)
