Old 04-09-2017, 12:53 PM   #16 (permalink)
pete c
Originally Posted by Wiegraf View Post
Not 2X horsepower. Im talking purely cruising...not makinh power. At most 4psi. Nothing more. We will handle one subject at a time.
Maybe I'm missing something here, but as I said before, if 2 engines are the same displacement, the turbo one, if it is making boost is making a lot more power. If you back off the throttle and run it off boost, the NA motor will get better mileage, partly because of the drag of the turbo, but more so because it is a low compression engine.
