Old 04-09-2017, 09:35 PM   #19 (permalink)
Wiegraf
Driver Mod
Wiegraf's Avatar
Coqui - '99 Honda Civic DX
Originally Posted by pete c View Post
Maybe I'm missing something here, but as I said before, if 2 engines are the same displacement, the turbo one, if it is making boost is making a lot more power. If you back off the throttle and run it off boost, the NA motor will get better mileage, partly because of the drag of the turbo, but more so because it is a low compression engine.
Like i said ... drag of turbo is like a muffler if anything.. so delete a catalytic converter (rear one) when you install turbo.. offset Mechanical efficiency.
And I'm never refering to POSITIVE PSI.....
Only vacuum....
Small turbo at 18 inHg vs N/A at same 18 inHg .. thought turbo would do better.
(I've adjusted my thinking now)
Current garage
- 1979 mustang street/strip
- 2010 Hyundai Accent GS 5-Speed (hate this things final drive)
