Old 04-09-2017, 09:33 PM   #23 (permalink)
pete c
Originally Posted by Wiegraf View Post
You're thinking incorrectly...and maybe I am too...I'm just thinking a small turbo would "push" more air in rather then making engine suck.
Actually, his thinking is spot on.
You seem to have trouble understanding how a gasoline engine controls power output. If you are close to atmospheric pressure at the intake manifold, you are either running a NA engine at wide open throttle or a turbo engine at a lower throttle opening combined with boost. The result is high power output, which as he said will result in a much higher speed.
I think the problem may be that you are thinking in terms of engine efficiency, rather than fuel mileage. A turbo engine, running with some boost very well may have a higher "efficiency", the problem is, it also has way higher aero drag because it is pushing the vehicle at a high rate of speed.
