Old 04-09-2017, 09:40 PM   #24 (permalink)
Wiegraf
Driver Mod
Wiegraf's Avatar
Coqui - '99 Honda Civic DX
Originally Posted by pete c View Post
Actually, his thinking is spot on.
You seem to have trouble understanding how a gasoline engine controls power output. If you are close to atmospheric pressure at the intake manifold, you are either running a NA engine at wide open throttle or a turbo engine at a lower throttle opening combined with boost. The result is high power output, which as he said will result in a much higher speed.
I think the problem may be that you are thinking in terms of engine efficiency, rather than fuel mileage. A turbo engine, running with some boost very well may have a higher "efficiency", the problem is, it also has way higher aero drag because it is pushing the vehicle at a high rate of speed.
Maybe I'm thinking efficiency will improve mph too much. And i was thinking lowèr inHg was just making it easier on motor. Makes sense though now.....
What about same inHg though.
Current garage
- 1979 mustang street/strip
- 2010 Hyundai Accent GS 5-Speed (hate this things final drive)
