Old 04-10-2017, 10:34 PM   #47 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Wiegraf View Post
Literally all i needed from tbe get go... now... curious what about.... both cars at same inHg.
Just for my last curiousity. Will the BSFC help?
Both cars cruising at 16.29 inHg.
Thank you again for bringing it to me Barney style.
If I understand you correctly both cars at 16.29 Hg. which one will be more efficient? If the compression ratio is the same and the cam profiles are the same both will have similar efficiency, but that's not the case in the OEM market with a petrol engine the turbo cars engine will have a lower CR and turbo cam profiles that will make a higher numeric BSFC number.
Pressure Gradient Force
The Positive Side of the Number Line
