Old 04-12-2017, 01:00 PM   #16 (permalink)
freebeard
All these responses clearly did not read my original post. So before you reply how about you actual read what I was asking.
[snip for potty mouth]
MY QUESTION:
"Is there a similar build as the Centurion that would allow me to get those kind of MPG? Kit? Any other success stories like the Centurion that is well documented?"
Is a Honda insight similar to a Centurion build??? NOPE
Is a Prius similar to a Centurion build??? NOPE
[snip for arrogance]
If you are not responding to my question about similar builds to the Centurion then move on. And if you think your [snip] is similar to a Centurion then your opinion is worthless.
You cast a wide net. When are you going to answer my questions?
I took a look at the Urba Centurion. Why would you want something like that piece of, um, 'automotive excrement'? Put a TDI on a Beetle floorpan. You want flex, add track and wheelbase with long arm A-arms and extended shock mounts. Then you can choose from a plethora of low-drag bodies.
A friendly suggestion: Expurgate your l*ngu*ge, the mods are watching.
