04-13-2017, 10:35 PM
#10 (permalink)
Eco Sol
Edited for US measurements.
Originally Posted by oldtamiyaphile
Don't bother.
My van averages 6.7 (35.1mpg) city (16mph average speed) and on a really bad day 9.7 (24.25mpg) with a 500kg+ (1100lb+) trailer.
If you work that out that's 0.006l/100km per kg (0.0025 gallons per mile)
Those are worst case figures because a trailer also adds rolling resistance, rolling inertia and completely ruins my aero (it's a big tall box). I also EOC normally but rarely do with the trailer.
My van had a 0.33 CD and I coast down tested the van+ trailer at 0.45CD
If I type those numbers into the calculator, I find that with a .33CD I should be getting ~6l/100km (39.2mpg) at 50km/h, and with a .45CD I should be getting 8.7l/100km (27mpg). So it seems that my 500kg (1100lb) trailer is only costing me an aero penalty, the weight is doing little to nothing.
A lighter car will sit higher on it's suspension so could actually cost you economy at higher speeds.
So on my new van I happily fitted a heavier radio, speakers, sound proofing and even an active sub, as the comfort, convenience and enjoyment is worth the extra 0.000-0.001l/100km (0.0004 gallons per mile) or so it might cost me.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
