removing the air box set up and just running a cone air filter off the manifold
i was considering removing the air intake system and just running a filter off of the intake manifold. Reasons: weight reduction of the whole set up and i have a map so no oil issues. And it would basically act as a wai since it would be right there basically on the side of the engine. Issues air intake tempature: what is good and what is bad. Wai temps get too hot ill lose timing advance and such. And lack of power (dont use it at all but dont want to lose some if i lose mpg.
