Old 04-16-2017, 08:30 AM   #9 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Got some more progress done tonight!
I figured out why I couldn't adjust O2 voltage with my FI/C-6. Boomslang tapped the wrong wire. I had to tap #10(?) wire, which is red, on plug D of the ecu harness instead of whatever wire they had tapped, and presto! It worked!
So onto the next step. I revved the car to 2000 and adjust voltages, then wrote down the corresponding afr and STFT.
I then installed my 248cc Toyota Camry plug and play injectors, made the necessary adjustments to my fuel map and BAM! runs great, definitely idles smoother and my STFT are +/- 5% (within acceptable limits).
Next step, is to fabricate turbo manifolds and what not. More to come this week!
A little extra: The car definitely idles smoother. I think this is because the stock Honda Insight injectors are only 4 hole, and the Camry ones are 12-hole. I am now getting better fuel atomization as a result.
