Originally Posted by pete c
It kind of almost sounds as if rigging up all these switches and manipulating things as you say, in addition to being entertaining, might also serve to do the job of a grid charger. Is this an accurate statement or should the GC be part of the equation as well.
Unfortunately, no. The car will generally only charge the battery to about 80% of its actual capacity (it might charge to 100% when it's recalibrating, but I can't remember). The purpose of a grid charger is to charge it to 100% and slightly overcharge the cells that get there first in order to get the others to 100%. This balances the pack. It's not as good as breaking down the battery and balancing each stick individually, but much easier and good enough in most cases.
