It really don't matter right now. With those dry readings, the test has already failed and if the car does not smoke, then it's time to replace the exhaust valves. Doing the ring job is up to you.
You say you are moving and don't plan on dumping any money into the car, but if you like this car, you may want to reconsider fixing it especially if you have trouble locating another Swift to replace it with.
Whatever you decide to do, we can help you along the way!
GeoMetroforum.com - got mpg?
