Old 04-21-2017, 04:11 PM   #12 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Alex, I also have a commonrail turbodiesel in my Peugeot 307, and I cut not the cam, but the crankshaft sensor. I seem to remember that cutting the signal from the cam sensor would not kill the engine, or would add some other unneeded complications, and that is why I had to try my luck with the crankshaft sensor.
In the case of my HDi, cutting the crankshaft position sensor kills the engine without reseting the ECU, but I do get a message about oil pressure being too low.
It logs an error code, but the engine can still be bump- or key-started. The error code can later be deleted with an OBD tool.
