Old 04-26-2017, 03:58 PM   #6 (permalink)
Andyinchville1
Please post photos of your vehicle and provide measurements on the ground clearance of the front chin spoiler and the height on the sides where you are looking to install the skirting.
I'm just thinking this is a case by case thing, not sure there are many advantages if the side skirts end up lower than the front. You don't want to go into hovercraft mode on the highway - just saying.
HI,
I can't seem to get pics on here but my car is a standard (well except for some of my mods!) 2003 VW jetta TDI 5 sp Station Wagon.
The approx dist from the ground to the underside of the front "valence" is about 6 inches off the gound
Jettas have a plastic engine compartment belly pan...That is behind the front valence somewhat but it it about 4 inches of clearance under there to the ground
The front side just ahead of the front tires is about 4 inches.
just behind the front tires is about 6 inches to the ground
just in front of the rear tires is about 8.5 inches to the ground
the underside height at the end of the rear bumper is about 13 inches to the ground.
The lowest point under the car is the engine belly pan....it is shaped to seemingly deflect air towards the ground.
Hope this helps.
Andrew
2003 Jetta TDI Wagon, 5 sp, 210K miles, Stock.....for now!
