Most of it was pretty interesting, though not all of it was effective! I haven't done a chin spoiler yet, but am planning on doing that after I finish the passenger side skirts.
At the moment I'm working on the rear taper, and my results have been mostly inconclusive:
1) I know the non-tapered rear shell was not an improvement in FE or handling.
2) The initial cut taper on the sides made no significant change (20-30 degree taper).
3) Removing the non-tapered top entirely made a significant improvement (+5% FE).
4) Installing a somewhat tapered top made no difference vs no top.
5) Changing the side taper from 20-30deg to ~12deg seems to be a -5% FE.
I'm not sure on #5, since I fixed the A/C last week and used it a lot. So I'm running again this week with A/C and then probably next week without A/C to confirm. Basically I'm looking to get the rear taper "correct" before moving on to other areas like side skirts, bellypan, front spoiler, rear wheel covers, front tire air curtains, etc.
