Old 04-27-2017, 05:31 PM   #2 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
Welcome to Ecomodder! LPG Civic, that's awesome! You should add your car the the "Garage" at the top of the page. That way you can track your fuel consumption on the website to visually see your progress.
Until you make your MPGuino you can measure your fuel from tank to tank at the gas pump. If you would rather buy an MPGuino instead of buy one you can get it HERE.
There are also plenty of other modifications and tricks you can do to boost your mpg, if you want.
65+ Vehicle modifications
100+ Hypermiling/ecodriving tips
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
