Originally Posted by t vago
Not sure how the Arduino digitalWrite functions will interact with the MPGuino code, but I do not think they'll be a problem.
Hold off on code investigations for now. I re-tested the 0210 code with the Meelis hardware and Meelis resistor/diode array. Works as expected. I now have sufficient clip-on wires to make more robust tests. Will advise. Next test is to use the Meelis resistor-diode array to talk to Arduino Pro Mini board. I can't imagine what I could have possibly screwed up; it's just two components and a wire. Maybe something is wrong with the breadboard (melted inside, etc)
