Old 05-01-2017, 02:43 PM   #72 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
Well, the phase correct PWM did not really work. So i will be using 30Hz, which is not at all bad.
With the canbus shield attached some of the pins on the arduino do not work. But i found some that do. I will later investigate why this is so, but not at this moment, want to get this thing it to the car as quickly as possible.
The injector gets really hot after a short time of operation, so it would be a good idea on my part to implement some sort of mechanism to check if there is water flow to the injector to cool it.
