Old 08-17-2008, 02:32 PM   #499 (permalink)
drivenByNothing
iduino and radioshack 4x2x1 case. Not perfect, but as close as I need it to be.
This required a lot of cutting not only to the enclosure, but I also had to cut the LCD board's corners off to get it to slide between the parts inside the enclosure that accept the screws. The rear terminals are for +12v, ground, Injector, VSS.
