Old 05-05-2017, 08:46 PM   #7159 (permalink)
duncan2
Hi Things
This my "Device"
I'm direct drive to the diff so I am going to use the old ABS sensors on each wheel as my data for the traction control and also the speed/rpm limiter
I was thinking about adding the two rear wheel speeds together and comparing to the sum of the two front wheels
I was thinking of a separate module interfacing with the throttle input on the main controller
So it would drop down the throttle input when the tires start to spin - as opposed to just now when the first thing I know is that the tires scream and the back overtakes the front
The damn thing won't let me post the link!
I'm on DIY - Electric Car as - "Duncan's Dubious Device"
