The average power drawn by the AC compressor is proportional to how much cooling you draw from the system. The compressor is clutched on and off to maintain the high side pressure. The compressor clutch is directly controlled by a pressure switch.
The compressor is sucking a lot of power when it is running, while the mileage hit is proportional to the percent of time it is running.
The more air you push through the system, the more the compressor runs. The slower the heater blower speed, the less cooling and less average power to the compressor. If the slowest setting on the heater blower is more cooling than you need, then add a resistor to slow the blower even more.
Look for ways to use less cooling. Sun shades when parked to keep the interior cooler. Interior as warm as you can comfortably tolerate. And pull the compressor fuse when running the defroster.
